16clb battery- need same size but opposite terminals
Results 1 to 6 of 6
    Jul 2018
    Coastal, NJ
    Does anyone know if they make a battery roughly the same size as a 16clb, but with the positive terminal (as you look at the battery) at the front left instead of the front right. Thanks.
    Aug 2011
    Austin, Texas, USA
    Re: 16clb battery- need same size but opposite terminals
    https://www.yuasabatteries.com/battery/gyz16h/
    There are lots of choices. Most manufacturers make them with terminals on different sides to allow for different mounting options. The positive terminal on the right version of the above Yuasa is the GYZ16HL, with the "L" for left negative terminal (or perhaps left positive terminal looking at the battery from a different position): https://www.yuasabatteries.com/battery/gyz16hl/
    Riding mostly Lake Austin
    I've had VERY good luck with this brand, been using them for 6 or 7 years, probably have sold 50 or more. Have them in my own skis and my atv. This is pos on left.
    https://www.chromebattery.com/ytx20-...s-battery.html
    Or gel for a bit more money WITH a charger..https://www.chromebattery.com/ytx14-...-html-pro.html
    Jun 2011
    Myself,
    Great info! I love that voltage window on the AGM battery! Such a great idea and a great price WITH a smart charger! I need 2 batteries for my skis and will give this brand a try.
    Thanks for the info!
    What would Chuck Norris do?
    You bet.
    Jul 2018
    Coastal, NJ
    Thank you guys for the helpful info.
