Keihin CDK2 Plastic flared nipple of carb to return line cracked
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Plugging carb for pop off test found return line plastic nipple on the brass pipe hairlined cracked.
    Bad air leak from plastic shank when pressurizing. Can a new one be found ? Is it threaded , heat welded ?
    Just try a epoxy repair ? Yep may have been leaking fuel for someone.
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
    Apr 2009
    Reno,Nv.
    Re: Keihin CDK2 Plastic flared nipple of carb to return line cracked
    Well, I just cut off the cracked plastic nipple to expose the knurled brass end of brass tube into carb.
    Probably in future will pull that out and get proper new fitting, but for now I think with hose clamp it should seal for a season.
    My bro-in-law has been riding his like that for several years lol!
