Flywheel Need to be Removed to Split Crankcase? 750sx
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Aug 2018
    Texas
    Does the flywheel need to be removed to split the crankcase? Only trying to replace the crank seals. I have a coupler tool and removed the first bolt by the flywheel. Do I need to take out the entire flywheel?
    I don't have a flywheel removal tool / bolt.
    Re: Flywheel Need to be Removed to Split Crankcase? 750sx
    Yes, how exactly would you replace the front crankshaft seal if you didn't remove the flywheel , Magic ?
    Aug 2018
    Texas
    First time doing this. Have a manual, trying to figure it out. Not sure how to remove the flywheel; hence why asking.
    Sin City USA
    You need to remove it to get at the front seal, as WFO pointed out. The flywheel removal bolt is an 18mm x 1.5 hardened bolt. Specialty hardware stores or bolt companies online are your best bet for something less expensive than the one you would buy from Kawi.
    Aug 2018
    Texas
    Thanks, just ordered one.
    Sin City USA
    Impact wrench and they usually pop right off. Don't get crazy and strip out the threads. Some are a little tougher and require some controlled tapping with a hammer, especially if it is the original and has been on there for almost 30 years...
    Make sure you lap the crank snout to the flywheel when you reinstall it. Use valve grinding compound. Use red loctite on the flywheel bolt (I personally NEVER reuse flywheel bolts) and torque to spec. Re-torque after a few hours of riding.
    Aug 2018
    Texas
    Yes, this is the original flywheel and never removed — original owner and engine never opened. I’ll be careful with the threads. I don’t think the crank seals are bad, but following the advice of the forum to change them out while I can. I had to look up how to “lap” but I get it now .
    Also you can apply some heat to the hub of the flywheel with a propane torch, this will help it pop off.
    Aug 2011
    Austin, Texas, USA
    Two piece split seals installable without removing the coupler or flywheel. You do have to cut the old one off. The new style is Kawasaki part # 92049-3719/unobtainium
    Riding mostly Lake Austin
    Aug 2011
    Austin, Texas, USA
    I found an alternate part: 92049-F4K3
