Flywheel Need to be Removed to Split Crankcase? 750sx - Page 2
Results 11 to 20 of 37
    Re: Flywheel Need to be Removed to Split Crankcase? 750sx
    I always used BR549 seals , I don't even split the case though just drive em home with a BFH
    Aug 2018
    Texas
    Impact wrench and they usually pop right off. Don't get crazy and strip out the threads. Some are a little tougher and require some controlled tapping with a hammer, especially if it is the original and has been on there for almost 30 years...
    Make sure you lap the crank snout to the flywheel when you reinstall it. Use valve grinding compound. Use red loctite on the flywheel bolt (I personally NEVER reuse flywheel bolts) and torque to spec. Re-torque after a few hours of riding.
    I'm trying to get the flywheel off now. Have the coupler tool locking down the coupler (with a steel tube hitting against the garage floor so it doesn't move). Also have the flywheel removal tool (pin) screwed in the flywheel side. This thing won't budge. Wanting to ensure that I don't do anything incorrectly.
    My next step is to apply some heat and then maybe tap with a hammer. Let me know if anyone has additional advice.
    Aug 2018
    Texas
    Quote Originally Posted by keck View Post
    Heat worked!
    Aug 2018
    Texas
    What happens if I removed the flywheel prior to removing the coupler? Do I need to reassemble and start over?
    Aug 2011
    Austin, Texas, USA
    You can try the rope trick in the cylinders or put the flywheel back on.
    Riding mostly Lake Austin
    Apr 2006
    Oregon
    Since the crank is coming out anyway simply mount the rear crank web in a vise, heat the drive coupler to soften the Loctite and remove the coupler.
    Home of Newmiller Machine
    Aug 2018
    Texas
    Is it correct to put the portion of the crank circled in blue into the vise? (see photo)
    Sin City USA
    NO, you are going to damage the key or worse. Remove the crank from the case, and do as Newmiller said.
    Aug 2018
    Texas
    Ok. Was trying to follow Newmiller's advice -- just didn't know which piece was the "rear crank web".
    Sin City USA
