1989 seadoo 587 full build!! Pipe, Cylinders, prop, etc.. - Page 3
Results 21 to 30 of 48
    Re: 1989 seadoo 587 full build!! Pipe, Cylinders, prop, etc..
    In reality 50MPH should be your goal, a stock 93 XP which was 80 HP only ran 46-47 MPH, the 93 hulls were only slightly bigger and heavier
    Aug 2013
    United States
    Well Ill be honest I have never driven these and was only looking at online "specs" Which said this ski stock back in 89' was 40mph. I have read alot of people saying they where going 50 in a 720 so I figured since I have some LB's on those 720's that maybe I could get close to 60..?? I guess will see, 60mph is steep but I figured I could go 55, who knows. I should be able to finish it up tomorrow and test run it so ill update then
    If you could get that thing up past 46-47 it would chine walk so bad it wouldn't be ridable, that is the way all the 93 models were before the recall to put rear sponsons on came out.
    Aug 2013
    United States
    Well.. my starter relay went out (least I think) So i have to to order that. ..will update next weekend
    I dream skis jetbum's Avatar
    Oct 2004
    Dirty River Rider Dunnville, Ontario
    I just picked up a 89 I plan on restoring
    1989 sea doo resto mod in the works
    Aug 2015
    Birmingham
    Yellow 580 sp just rolled up here too, I'd like to punch it out just cause the pipes are cheap, but my buddy would just want it easy and reliable
    Oct 2004
    Has anyone ever ported a 587. I found some specs online. Or even just clean up the ports. Haven't taken motor fully apart yet
    Quote Originally Posted by jetbum View Post
    Yes, I've done a couple. I have a nice ported one sitting on a shelf right now!
  9. #29
    The "secret" to a quick 580/650 is a single 44 carb.
  10. #30
    And spinning the Bejessus out of the engine, a 587 only turned 5550 RPMs, 657's and 717's turn 7000, it just makes sense especially with porting, a pipe and big carb that you need to turn RPMs to make power especially on a smaller engine, a 587 will pull really well up top but it will never have the bottom end power of a 657 -717, fortunately the hulls on the older skis were much lighter
