cutting aluminum impeller diameter
    PWCToday Newbie RLHDWEPWCGUY's Avatar
    Jun 2017
    southeast WI
    Does anyone on this site have the ability or know someone who can 'recut' a tapered aluminum impeller. Such as taking a worn out one welding new material to outside edges which I can get done, but then finishing it to proper size to fit in the wear ring. The west coast firms do not do this. My old Wetjets use this type of impeller so did the Kawasaki 550's.
    2006 Kawasaki 15F
    1991 Wetjet Sport II
    1992 Wetjet Sport II Spirit
    Frequent Poster Dave in DE's Avatar
    Apr 2016
    slower lower Delaware
    Re: cutting aluminum impeller diameter
    Have you tried Impros? I believe They recondition props and impellers.
    Anybody with common sense, basic measuring tools, and a lathe can do it. Measure the taper, set up a cutting guide on the lathe, then weld and regrind. But good luck finding a real machinist these days and not just some empty shell of a body standing in front of a machine tool.
    Jun 2017
    southeast WI
    That's why I am asking here, lots of watercraft information, & no Impros doesn't do old aluminum impellers, I have used them to do my 15F impellers over the years.
    2006 Kawasaki 15F
    If you can explain to a real machinist what needs done they can do it.
