Too much Oil?
Thread: Too much Oil?
    I dream skis scottw090's Avatar
    Jul 2015
    Huntsville AL
    Too much Oil?
    no such thing... right?
    I haven't figured out how this happened yet. Pressure in the oil system ? there was probably a gallon + of oil in the bottom of the hull , previous owner seemed to be putting oil in the tank and it was being pumped .... everywhere. The best part is that the ski ran when my brother bought it.
    Frequent Poster Dave in DE's Avatar
    Apr 2016
    slower lower Delaware
    Re: Too much Oil?
    What year and model?
    Jul 2015
    Huntsville AL
    Re: Too much Oil?
    96 kawi, does it matter?
    Re: Too much Oil?
    Kawi check valves are in the little oil line fitting on the carb. Some gunk held it open. Usually a blast of carb cleaner then compressed air gets them freed up.
    Austin, Texas, USA
    Re: Too much Oil?
    Easy fix: go premix
    Riding mostly Lake Austin
    1984 JS440 -- 1989 650sx -- 1991 X2 -- 1992 750sx -- 1995 900zxi (qty 2) -- 1995 X2
    Quote Originally Posted by cujo View Post
    God intended PWC to be two strokes, as well as dirt bikes, snowmobiles, and chain saws....
    Jul 2015
    Huntsville AL
    Re: Too much Oil?
    Oh yes this motor is going to go into an sxr or blaster and there will be no oil injection, this was was the initial tear down of the couch.
