93 X2 Carb Needle and Seat
    Oct 2017
    Discovery Bay
    Itís time for a rebuild on the stock 38mm on my x2. My understanding is the needle and seat should be replaced as well. Is this true? If so, where the heck can you find the n&s? Google has not been particularly helpful.
    Thanks!
    Riverside, CA
    6
    Re: 93 X2 Carb Needle and Seat
    No, if anything needs to be replaced, replace the needle.
    Reuse the spring.
    Were you having any hard starting problems? Why are
    you rebuilding the carb??
    Bill M.
    Oct 2017
    Discovery Bay
    Reuse the spring.
    Bill M.
    Yes I was having hard starting problems when it was warmed up.
    Riverside, CA
    6
    Quote Originally Posted by roush611 View Post
    These are the extra steps I used eliminate the common vacuum
    leaks as a tech, when I rebuilt Keihin carbs with hard starting problems.
    Bill M.
