Drivetrain insrall on ZXI
Results 1 to 2 of 2
    Jul 2003
    MA
    Engine and carb rebuild is complete. I also remove the hull bearing holder and replaces the bearings. The pump is still in.
    I am ready to reinstall but a little unsure of the process. I am planning to drop the exhaust chamber into the hull. Then insert the driveshaft with the holder on it. I would then drop in the engine while connecting the driveshaft. Once the engine is mounted I will silicone the holde and bolt it in. Then I would connect the exhaust and install the carbs.
    Any need to align or shim the engine if the beating holder isn't in place?
    Should I silicone the hull before dropping in the engine?
    I will be doing almost the same process with a 650sx in a few weeks.
    Jul 2003
    MA
    Re: Drivetrain insrall on ZXI
    All set. I found the info.
