Yamaha Wave Venture no spark...again
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jan 2018
    Albuquerque
    95 yamaha wave venture 700. Last year had no spark and after doing alot of trouble shooting, found it was the stator. Went to fire it up today to get it ready for season....and guess what? NO SPARK AGAIN!!!! Checked all conections, fuse, kill switch and all is good. Im guessing its yhe stator again! I already ordered one so we'll see what happens when it gets here. What would cause it to go out again? Im about ready to go to lake and just sink this damn thing!
    Aug 2007
    Re: Yamaha Wave Venture no spark...again
    I take it you didn't buy the oem stator assy, right?
    If not, that's the problem. They can't seem to figure out how to make a proper working stator. Buy a good used one. Yamaha stators rarely ever fail.
    Jan 2018
    Albuquerque
    I bought an oem one the 1st time. If i remember correctly it was about $350 or $400. This time i bought an after market one.
    You may have an excessive electrical draw somewhere. Possibly a faulty voltage regulator.
    Jan 2018
    Albuquerque
    Is there a way to check that?
    You would put a meter across the battery terminals and check voltage. Then start it up and rev it while watching voltage. If it goes crazy like 16 or 18 volts that could be the problem.
    Jan 2018
    Albuquerque
    As soon as i get the stator in and installed i will check that. Thanks for the advise
    Thinks everythng sux =) Top Dog vomitspot's Avatar
    Mar 2005
    lost
    jss can rebuild your oem stator
    nina hagen daz
    Jan 2018
    Albuquerque
    Ok so i got the new stator in and installed and still no spark!!!!! What do i check now?
