650 protec pipe on 701
Results 1 to 8 of 8
    Frequent Poster RiverWF's Avatar
    May 2010
    boulder city
    I have this 650 square nose with a pro tec pipe on it. Is this specifically for the 650 or would It also work on a 701? Attachment 548660
    Dec 2009
    Buffalo
    Re: 650 protec pipe on 701
    What 701? 61x or 62T? You may have issues with bolt hole size on a 62T and may need to open/port match the manifold to the cylinder on either 701 application.
    Michigan
    I run one on a ported 64X 760. I love this pipe. Just make sure all of the mounting hardware/ rubber grommets are in good condition. I just replaced all my mounting bolts and grommets this winter. These pipes can come loose and cause issues if not monitored and inspected regularly. Good, solid and new hardware eliminates most concerns.
    Also, some of the pipes I have seen have one mounting tab to the head and some have two. However, the manifold and pipe appear to be the same. They make really good power and sound really good as well.
    Aug 2015
    Birmingham
    Yes and will hit hard as ****
    Aug 2015
    Birmingham
    And use factory bpipe jetting
    May 2010
    boulder city
    Quote Originally Posted by Rushford_Ripper View Post
    61x. Thank you!
    May 2010
    boulder city
    Quote Originally Posted by JSNate View Post
    Mine has 1 tab. Thanks for the tips!
    **** ya! thank you for jetting info
    May 2010
    boulder city
    Nate your pipe is so pretty
