JS 440 Electrical Box
    Jul 2018
    Boise, ID
    Hey guys,
    Iím trying to replace one of the fittings that is broken on my JS 440ís electrical box. A previous owner tried to glue it to fix it by gluing it and it just ended up breaking again. Iíve taken the 5 bolts off the front but it wonít budge. Iím thinking maybe some of the glue may have gotten in between the two halves of the box. Does the box usually open easily after the 5 bolts are taken out or am I missing something? Iíve also tried to look at the schematic but I donít see anything. Thanks for your help!
    Emily
    SE MI
    Re: JS 440 Electrical Box
    There are 6 bolts that hold those boxes together - 4 are mounting bolts and are ~50mm and two that tighten from the rear that are ~20mm long.
    Jul 2018
    Boise, ID
    Thanks so much! We found it hiding under a cable. Thanks again.
    Jul 2018
    Boise, ID
    So I’ve got a quick follow up question. My hubby was telling me I might need some dielectric grease for the new connection. Do you guys use that for this fix?
