How to get more torque
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    Feb 2018
    Manteca, California
    Okay so I️ll start with my ski itís a 91 with umi, Prowatercraft ride plate, Westcoast intake grate(have a top loader to put on), 10/16 hooker, factory pipe for a 650 , 750 small pin believe I️t has unmarked cylinders, prowatercraft drive shaft fill, and Sxr carbs Iím sure I️ forgot something but that should be about I️t with me being only 17 Iíve got a little under 2000 into the hull build and I️ gpsed I️t at 52.2 while my dads 800 goes 53.2 so Iím good with top end just want to know how to get a little more torque. Things Iíve thought about is 2inch exhaust, high comp head, or lighten flywheel. Any input is welcome just donít want my dads ski beating me so badly on bottom end lol. Thanks in advance
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: How to get more torque
    Higher comp head and a lightened flywheel is a good start. For ease and reliability find a 750 D stamp head, with the small pin cylinder that will bring you to 170-175ish psi, which is perfect for 91 pump gas.
    -95 750SXI
    -90 TS650
    -81 JS440
    Parts for sale HERE
    Head, flywheel, timing, AND 2" exh are all good things, and will increase bottom end throttle response.
    email watcon@watcon.com
    Please visit our web sites
    charlotte,nc
    Definitely milling the head will make a big difference. Lightened flywheel will help the ski rev quicker but it's not gonna be a very dramatic increase. Since you have a factory pipe, you can play with the water screws that will change the tuned length of your pipe. The 650 chamber on the 750 engine is gonna be more like a top end hp setup anyways. I've got a very similar setup as you with a #22 cylinder, milled head, lightened flywheel, sbn 44 and hooker 9/15. I started playing with the water screws and saw a dramatic increase in bottom end after opening the screws. I started with just the top opened 3/4 turn and ended up with 2 turns on the top screw and 1/2 turn open on the middle and it has lots of bottom end torque now. I'd recommend playing with your water tuning on the pipe first since it's free and you could do it anytime. Open the screws until you notice the top end fall off the on close whatever screw you opened last a 1/4turn back in. more water in the pipe= more low end torque, less water= more top end hp
    What cdi are you running?The kawi part#3738 cdi has great advance and good retard up top. Power comes in hard. Came stock in 94 XiR and 98-02 Sxi pro.
    I saw a decrease in acceleration when I had the Prowatercraft stuffer in the pump cavity.
    SE MI
    Water injection can help also, you can do this with your head pipe or add a unit from MSD or Microtouch. I run this on two of my Kawi motors and both have factory pipes, they work well.
    Jan 2007
    Earth (but just visiting)
    What RPM are you turning topped out on flat water in 100 feet?
    Dec 2009
    Buffalo
    I'm running a 750sp, ADA head bumped to only about 10psi more than stock, lightened flywheel, 10/16 hooker, 650sx style nozzles (removed the trim), 1" spacer, 87mm bored nozzle, the extended PJS rip turn, stock pump cone, R&D 750 pipe, 94/95 waterbox, every bit of the exhaust is 2", RCJS intake grate, and a sbn44.
    I have yet to actually test my build, however, it was built not for top speed but for quick bursts/surf. I would think your best first mods for your desired application would be to bump compression a little bit and lighten the flywheel as stated above.
    Apr 2006
    Oregon
    All good information in this thread... Compression increases produce almost all torque so probably want to start with what bandit mentioned. If you are running the stock "A" casting head that came stock with the #20 cylinders you are leaving a lot of bottom end grunt on the table. And like that fairlane character mentioned, check that your water injection bleeds are not clogged and tune the head pipe for bottom end. After those two things if you still want more throttle response start going through the rest of the suggestions including pump tuning (impeller pitch/nozzle diameter) like I think stratton was getting at.
    Home of Newmiller Machine
    Feb 2018
    Manteca, California
    Okay so as far as cdi I️ have one out of a sit down I️ believe it’s not the good #3738.So if I️ change to the #3738 you guys think I️ll gains bottom end? But will I️ Sacrafice a lot of top? And a lot of you guys recommend high comp head first so I️ might do that and lighten my flywheel since I️ have a spare flywheel I️ can get I️t sent off during the summer just need to make sure I️ get my summer job. And how do I️ know if my factory pipe screws are working correctly is I️t just to make sure they turn freely or is there something else I️ need to do? Will I️ lose a lot of top end adding water? And also kind of a side question are the single carbs better at low end or is I️t duals? Appreciate the feedback from everyone has been very helpful.
