How to get more torque - Page 3
Results 21 to 30 of 33
    Apr 2006
    Oregon
    Re: How to get more torque
    Do the compression bump first, especially if you have a stock "A" or "B" casting head. PWI requires installation of a control unit, solenoid, spray bar and a suitable area near the exhaust manifold/head pipe connection that is solid aluminum (no water jacket) to install the spray bar.
    Home of Newmiller Machine
    Feb 2018
    Manteca, California
    as far as the connection needed would the surf beace work or does I️t need to be connected to the motor?
    charlotte,nc
    Man play with your head pipe screws first.
    Feb 2018
    Manteca, California
    I️ will haven’t been to the lake yet I️ll try that first. Appreciate the advice
    Feb 2018
    Manteca, California
    Also what’s your guys opinion on the r and d pump stuffer?
    Riverside, CA
    6
    Do you even know how much compression your engine produces?
    Do you want to keep it running on pump gas? If so bumping up
    the compression to 185psi will only be about 10 to 15psi over
    stock.
    If you are looking to just remachine your cylinder head, that is
    a waste of money. It's not like you are going to increase the
    compression significantly, like an old pp550 that had 125psi stock.
    On the pp550 it was common to bump the compression to 175 to
    185psi (a 50 to 60psi increase).
    On a 550, there was room for a ~48% increase in compression.
    But on a 750, the pump gas limit only leaves room for a ~9%
    If you still want to increase your compression, reduce your squish
    and gain reliability and acceleration. You can do this by purchasing
    an ADA billet head, or decking your cylinder.
    But the easiest way to increase power and acceleration is to
    Reverse Jet your SXR i-body carbs. All it will cost you is a little
    time, 4 jets, 2 springs, new gaskets, and very important: use
    your stock 1.5 needle & seats.
    Bill M.
    Feb 2013
    NorCal
    Bill!! You are alive!!
    Chicago / Portage, MI
    He is alive!
    Bill, do you have any guidelines on jet selection for reverse jetting the Mikunis? I'm curious how it compares to factory pipe's jetting. Which so far on a variety of flame arrestor / piped skis has been pretty good.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
  9. #29
    Quote Originally Posted by Mythenand View Post
    Okay so I️ll start with my ski it’s a 91 with umi, Prowatercraft ride plate, Westcoast intake grate(have a top loader to put on), 10/16 hooker, factory pipe for a 650 , 750 small pin believe I️t has unmarked cylinders, prowatercraft drive shaft fill, and Sxr carbs I’m sure I️ forgot something but that should be about I️t with me being only 17 I’ve got a little under 2000 into the hull build and I️ gpsed I️t at 52.2 while my dads 800 goes 53.2 so I’m good with top end just want to know how to get a little more torque. Things I’ve thought about is 2inch exhaust, high comp head, or lighten flywheel. Any input is welcome just don’t want my dads ski beating me so badly on bottom end lol. Thanks in advance
    For more low end torque, also consider changing pipes. The 650 factory pipe is a good all around pipe, but my friend has a dual small pin with a waveblaster factory pipe and there is definitely more low end. The whole power band is shifted down a bit, but it hits pretty hard. I believe JonnyX2 had good results with them a while ago, as do a bunch of the X2 guys. The unmarked / 750sx cylinder with that pipe has just about the most low end on a stock 750 engine that I have ever felt. And we have maybe 10 750 engines in various skis in our riding group we can try back to back.
    Also low end/ freestyle porting. For most recreational riding that's the porting you want. Good results for the dollars you invest. With all those mods, unless you dad is running a ton of mods on a ported 800, you'll be decently enough out of the hole faster than him, that a 1-2mph advantage wont matter much. The 800s were only 5hp more, and have middle of the road port timing stock.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
  10. #30
    stock.
    Bill M.
    Sorry, respectfully, I totally disagree...
    Increasing compression 10-15 psi makes a noticeable difference in throttle response, and low end acceleration. Maybe not a HUGE difference, but very noticeable, and is part of an overall package.
    That, and reverse jetting IMO does not work. It is fine for a freestyle ski that is set up for all bottom end, and never sees WOT, but NOT in a rec set up.
    email watcon@watcon.com
    Please visit our web sites
