Carbon pipe build - Page 6
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
  1. #51
    Top Dog Hydro-Mike's Avatar
    Sep 2015
    Northern Michigan
    Re: Carbon pipe build
    Quote Originally Posted by scensor View Post
    Great video, great work. Try to lower your volume of water at the waterbox. Also do you have a stinger size on the new pipe the diameter?? And do you spray water there??
    Also what rpms you see?? Or you don’t have any tach on it??
    Once I get the carbs where they should be I will start riding more and work on dialing in the water. Stinger is the same as the stock white pipe and no water at all. I do have a tach but no data yet. Once I have the jets here and get carbs right everything else will fall into place. Also remember this pipe is made for low and mid range. I really have no clue where the top RPM's will be, would be great if they where there but I am not worried about it.
  2. #52
    Super cool !!
  3. #53
    Dec 2009
    Buffalo
    We need to plan a surf day this season!
  4. #54
    Sep 2015
    Northern Michigan
    Quote Originally Posted by Rushford_Ripper View Post
    For sure! I will be on Erie in late June around the Sandusky area. I will bring my ski.
  5. #55
    Dec 2009
    Buffalo
    Let me know!
  6. #56
    Sep 2015
    Northern Michigan
    Got it dialed in. Idle is set low. Used a phone a friend to get it dialed in .https://youtu.be/pNE8i92fPEk
  7. #57
    Michigan
    Sounds great, Mike!
  8. #58
    Sep 2015
    Northern Michigan
    Quote Originally Posted by JSNate View Post
    Sounds great, Mike!
    Thanks Nate, soon .
  9. #59
    Sep 2015
    Northern Michigan
    Got out and did some testing and had a great time. The pipe is running great. Jetting is slightly rich right now. But the performance is there. Did some speed runs and the ski is accelerating strong all the way through the rpm rang. There's no hit, just a strong pull all the way to top rpm. Next would like to put this pipe on a kawidoo. Or throw it in a Rxx and compare it to twin pipes head to head.
  10. #60
