Changing popoff
Thread: Changing popoff
    Sep 2008
    The flakka capitol of Florida
    Changing popoff
    What do the 760 engines like? Going to lower the insanely high psi yam uses. Going to aim for mid 40s unless told otherwise
    Re: Changing popoff
    Put 95 gram springs in & leave everything else stock,richen LS 1/4 turn makes a huge difference.
    Idaho/California
    Re: Changing popoff
    2.0 n/s
    Black color code spring
    Sep 2008
    Re: Changing popoff
    Did this one as well as replacing fuel line. Sucked up fuel no prob and idles/revs up great
