Starter mount bracket on engine case broke 92 Yamaha WR3
    Jan 2019
    Trinity, North Carolina
    Question Starter mount bracket on engine case broke 92 Yamaha WR3
    Picked up a 92 Yamaha WR3 the starter mounting bolt hole on the crankcase is broken, the treads are gone and half of the bolt hole is broke off. What are some options here to fix this? I've got a spare crankcase but just wondering if anyone else has been able to "fix" the broken bolt hole besides replacing the crankcase.
    Aug 2011
    Austin, Texas, USA
    Re: Starter mount bracket on engine case broke 92 Yamaha WR3
    Haven't done this exact repair myself, but it sounds like you need to weld the material back on there and tap a new thread. There's enough torque from the starter motor that some cheesy repair like JB Weld has no chance of holding.
    Riding mostly Lake Austin
    Jan 2019
    Haven't ever welded but the bigger problem is that the other half is not available, I'm not sure where it ended up but when I pulled the motor it wasn't in the hull. So my option was to replace the crankcase.
    any good tig welder can fix this , you take a carbon rod smaller than the bolt size and put it in what left of the bolt hole then tig around the carbon rod, remove the carbon rod, drill and tap the hole to the correct size, install and ride
    Jan 2019
    Here is a couple of photos of the damage, threads on the piece still left are pretty much corroded away. So a good tig welder could fix that mount? That's nice to know, I'll have to see what a welder would cost me to do that.
    Jan 2019
    yes there is easily enough there to work with, like I said earlier any skilled tig welded should be able to fix that
