650sx CDK2 38 tuning
Results 1 to 8 of 8
    Jan 2018
    So Cal
    Hi All,
    have an 88 650sx with a 91+ CDK 2 38mm and proper sized intake manifold, smoothed out exhaust ports, stock 39mm non diverter exhaust manifold, mariner head at 170psi per cylinder, and a stock pipe that has had 4in added to the center section.
    The carb is jetted stock, 75 slow 140 main. I took her out last week after getting her back together with this newer motor / exhaust and had to turn the high speed out to ~1-1 1/8th of a turn from the sock 5/8ths. It seems to run well, but water was rough so i couldnt do much in the way of long WOT runs.
    Needless to say, my questions are. 1. how far out is too far on the high speed before i should consider going to a bigger main jet, 2. what do others think my jetting / screw settings should be for such a setup?
    Thanks!
    Jan 2018
    So Cal
    Re: 650sx CDK2 38 tuning
    Wow... no one has ever tuned a CDK 2 38mm on any 650 motor... i find that hard to believe considering its a stock carb.
    Just looking for starting points.
    Dec 2009
    Buffalo
    Usually between a 1/2 turn and 1 and a 1/2 turns out is good, anymore you would usually go up or down on jets
    Jan 2018
    So Cal
    Awesome.
    Any tips for idle to half throttle tuning. Ski runs great but has just a smidge of a bog if you wack the throttle from a dead idle.
    Green Bay WI
    Quote Originally Posted by nd4spdbh View Post
    Bog or hesitation? Bog = go leaner on the main jet, hesitation = go larger on the main jet.
    -95 750SXI
    -92 750SS
    -81 JS440
    Parts for sale HERE
    Jan 2018
    So Cal
    Ya know ill definitely have to play with it more on calm water, admittedly it was rather rough and rather hard to do tuning. It SEEMED to get worse the further out i turned the high speed screw.
    PWCToday Newbie Setbrew45's Avatar
    Oct 2015
    NW Indiana
    Following this post, I just got a 145 main 80 pilot ordered from sudco. I will let you know how that goes. Hope I guessed right at 10 bucks a jet!
    Jan 2018
    So Cal
    Quote Originally Posted by Setbrew45 View Post
    What kinda mods to your ski?
