750 swap wont start
    Frequent Poster slowx2's Avatar
    Jul 2006
    ND
    750 swap wont start
    Running out of ideas so figured I would see if anyone else has any ideas.
    I just swapped a 750 into an x2 and I cannot get it to turn over. It will turn over when you jump the starter solenoid. But this has been the case for 3 different used solenoids and one new one plus 2 different eboxs. I have also tried 3 different start/stop switches, 2 kawi and 1 yamaha. I feel like it has to be something dumb that I am forgetting to check so any ideas would be great.
    Current skis:79 js440/650 flat deck, 94 fx-1, 88 650sx
    Past skis: 91 550sx with 650 conversion, 88 650sx, 87 X2, 86 js550, 85 js550, 78 js440, 77 js440
    charlotte,nc
    Re: 750 swap wont start
    How do you have start stop wires connected? Check your fuse also
    Jul 2012
    milwaukee
    Try running a extra ground wire from the motor to the Ebox case.
    If has to be something simple.....
    If it will crank when you jump across the relay, your start, battery and cables are good.
    It may be a coincidence that you are trying multiple bad relays (Doubt it though)
    Same with the start switches. It is possible all the ones you are trying are also bad.
    I am guessing you have an issue in the start/stop wire harness where the switch plugs into, and goes into the e-box. Try using a paper clip to jump across the start terminals at the plug (Yel/red wire, and red/pur wire).
    If you cannot get it to crank jumping the wires, go over them going into the e-box. If you cannot see anything wrong you will need to break out the multimeter, and see where you are getting, and then loosing voltage.
    email watcon@watcon.com
    Please visit our web sites
    Jul 2006
    ND
    thanks for the help I am going to have to give that a try.
    Black to black white to white but the other 2 never match so I try connecting them both ways. I have not checked the fuse yet going to check that before I do anything else.
