1990 550sx to 750 conversion - can stock 750 exhaust be used?
Results 1 to 6 of 6
    Mar 2019
    Florida
    Hello I have found many threads giving me the options of 650 aftermarket exhausts I can use. Specifically I already have the stock 750 exhaust system can this be used? fit in the hull?
    Original build thread here: http://www.pwctoday.com/showthread.php?t=486710
    Thank you!
    PWCToday Regular PiranahIndustries's Avatar
    Nov 2016
    Chicago, IL
    Re: 1990 550sx to 750 conversion - can stock 750 exhaust be used?
    Most 650 AM pipes fit with little to no modification. For a 750 stock pipe to work, you would have to make quite a few changes to get it to fit. Some more discussion on this: http://www.pwctoday.com/showthread.php?t=456564
    Good luck with the build!
    1987 JS550/750 Conversion “Big Red”
    charlotte,nc
    if you need a 650 pipe, i have a modified westcoast pipe that i ran in my 550/750 conversion and it ran great. its been extended 3inches for better bottom end and the overall diameter of the center ribbed section enlarged for more power. also cut an angle into the outlet so it lines up nicely to the water box. no longer need it so ill make you a solid deal on it if youre interested
    Mar 2019
    Florida
    Quote Originally Posted by PiranahIndustries View Post
    Exactly what I needed to know, thank you !
    Mar 2019
    Florida
    Quote Originally Posted by wworrell View Post
    Yes I would be interested, let me know how much to ship to st pete beach fl or message me.
    Thank you!
    Mar 2019
    Florida
    Yes I am interested, message me or let me know
    Thank you!
