oil injection VS premix questions
    Jul 2018
    jmgh,gh,gh,fh
    Hi, 760 64x. Oil tank is broken so can't use oil injection. Going to run motor on 50:1 premix for now. Questions:
    Will running the motor with the oil pump dry hurt the oil pump?
    Does running premix vs the oil injection change the richness/leaness in the carbs? (which are mikuni 44's)
    Thanks.
    Re: oil injection VS premix questions
    Not a good idea to run the pump dry. It is lubricated by the oil going through it. Eventually it will ock up, and break.
    Get an oil block off, and remove pump, all lines, tank etc.
    Running premix makes no difference in carb jetting. The amount of oil you will have in your gas is really not very much. (50 parts gas to 1 part oil)
    email watcon@watcon.com
    Please visit our web site
    Oct 2013
    Ohio
    Technically running premix, leans your fuel mixture, by the percentage of oil in the premix. 50-1 = 2% oil. If your engine is running rich now, this may increase your performance a little. If you are running lean, on the low edge, this may push you over the critical edge.
    If you plan to return to Oil injection when you get a new tank, I would fill a length of oil line with oil and plump the intake to the outlet of your pump. That way your pump will continue to be lubricated.
    Be sure to block off the injection ports on the engine to prevent air from entering and making your lean condition worse.
    Jul 2018
    jmgh,gh,gh,fh
    I have the oil tank rigged up to feed the oil injection pump and have the lines to the carbs dumping into a pan while I run the motor on premix.I'm trying to determine if the oil system is working. How much should I be seeing coming out over the course of ,say, a 5 minute driveway run at idle. I put blue oil in and there was brown oil in the lines. After 5 minutes a bit of brown had come out, but not to the blue yet. How do I determine how much is correct and that the pump is working?
    Thanks.
    Jan 2012
    Georgia
    There should be a spec in the manual. Basically spin the pump at a certain rpm and measure the oil amount in cc.
    I usually stretch a bit of tygon over the tang and run the pump with a dewalt 20volt drill.
    XI Sport
    GP800R
    X2
    FX140
    May 2012
    Iowa
    The thing that concerns me running pre mix is if your carbs are running lean for some reason then your not getting enough fuel, if you oil is coming in with the fuel then your not getting enough oil either. With oil injection your always getting the oil as long as it doesn’t fail.
    Premix it & call it a day. 40:1 (16 oz oil to 5 gallons gas).
    A LOT of people tend to over think things around here.
