How do I remove the last darn bolt on engine mount?
    Jul 2014
    North carolina
    Looking to remove my engine to clean up and repair the exhaust manifold rust issue. But I canít seem to get to the last engine mount. How did you guys do it?
    is it possible to remove the exhaust manifold with engine in? It seems like thatís the only way to get to that bolt.
    Re: How do I remove the last darn bolt on engine mount?
    There's a good guide on YouTube I think it's jet ski junkies they show step by step how to remove the engine from a Honda aquatrax and there's a lot of stuff has to be taken out first before you can pull the engine. some of the guys say you can pull exhaust manifold without pulling the engine but it's difficult. Which bolt are you having trouble with?
    Banjomaniac
    Jul 2014
    North carolina
    I followed everything on that video but the bolt by the turbo is what I couldn’t get. It’s the engine mount bolt. My ratchet won’t have clearance. I will try just a wrench �� see if it works.
    It will come out just time consuming and hard. I bought some shallow sockets and I bent some wrench's just for the exhaust bolts.
    Banjomaniac
