657 engine/flywheel/armature
Results 1 to 10 of 10
    Nov 2010
    Wichita, ks.
    I picked up a 93 SPX in parts and pieces. The engine in it, sitting loose, has 657 marking on the mag housing. I got it put together and installed. Went to start it and all I got was a backfire out the exhaust. I followed the book on installation of the rotary valve. I checked the ignition timing like the book says with a depth gage on mag cylinder and then check with a strobe/timing light with it spinning free(plugs out). It looks to be way out of time. It looks like the mag housing and guts have been taken out at one time. Here's the question: how do I know I have a matched set of 657 engine with the correct flywheel and armature?
    Re: 657 engine/flywheel/armature
    You don't but it sounds like you possibly have the wrong flywheel on your engine which will indeed throw it way out of time, there are two different flywheels on a 657 the early style with the separate CDI box and the later style with the CDI integral with the MPEM.
    Nov 2010
    Wichita, ks.
    The flywheel I have looks like most any other flywheel out there for sale for a 657(non X) engine. How do I know if I have the early or later model?
    Nov 2010
    Wichita, ks.
    and it has the 5-wire stator
    Quote Originally Posted by brm1626 View Post
    Its very hard to tell them apart...the only difference is the keyway is clocked a few degrees different. I have still cant tell the difference between the two. I always go with a known flywheel & always mark them when I come across one.
    5 wire stator is the early yellow motor & 93-94 XP
    Really the only way to tell the difference is to look at them side by side and see where the keyway is located at
    Nov 2010
    Wichita, ks.
    any pics I can go to?
    post up a pic of yours after you take it off and I will see if I can help
    Nov 2010
    Wichita, ks.
    okay from my research I believe the four wire flywheel is part number 032000-8420 and has vc150 stamped on it, the five wire stator flywheel should be part number 032000-8420 and have vc139 stamped on it, I will look today and see if I can locate a four wire stator flywheel and see shere the keyway position is in relation to the magnets
