1996 Sea doo GTS blows 5 Amp fuse
    Mar 2017
    North Carolina
    The 5amp fuse blows as soon as the positive battery cable is connected. One leg of fuse is shorted to ground. When I remove the 4 pin Magneto connector the shorted ground goes away. I tested the yellow to yellow/black is 0.2 ohm and the black/red to black is 60 ohms. I've read til my eyes bleed and I'm sure there's something I missed in the manual. Please help.
    Re: 1996 Sea doo GTS blows 5 Amp fuse
    Replace bad mpem.
    Mar 2017
    North Carolina
    Thanks Grumpy....You're right. I just verified with unplugging everything from the MPEM and ground still there.
    Mar 2017
    North Carolina
    Quote Originally Posted by Jingles View Post
    Thanks again Grumps...received new MPEM, installed and starts right up. Now tearing into a 03 GTI LE RFI that has severe salt water cancer. Should be fun.
    I have lots of RFI stuff LMK if you need something. I might have it.
