Waterbox - Page 2
Results 11 to 13 of 13
Thread: Waterbox
    PWCToday.com Is My Home Away From Home jetskijockey's Avatar
    Dec 2007
    Eau Claire, WI
    Re: Waterbox
    actually with the west coast pipe too, go stock. Performance of that pipe on a 750 isn't anything special
    if the motor is unported and/or single carb, just get a stock waterbox and call it a day.
    x2!!!!
    Jul 2018
    WA
    Re: Waterbox
    If the motor is unported and/or single carb, just get a stock waterbox and call it a day.
    I have dual 40s. What would be the difference be performance and sound wise between the HX and unmodified stock box? I've read a few threads that the HX has a leg up on the stock. I'm aware that the westcoast pipe that came with the ski isn't all that great on the 750 but from my understanding it's better than a modded stock 650 pipe. Not looking to buy a coffmans or factory at the moment but maybe sometime down the road.
    Shiocton, Wisconsin
    Re: Waterbox
    If you want to run a true 2” system, why not have the stinger cut off the end of the westcoast pipe and have a 2” welded on? I never hear anyone talk about this, but it would be first grade work at just about any fab shop and shouldn’t cost much. Then add a 2” in/out HX box and a 2” hull exit.
    If you want to keep things simple, just leave it 1 3/4” and drill the stock box. That should work pretty well, and will sound nice but not crazy loud.
    As far as performance, to me, there is way to many variables that contribute to the over-all
    performance of any given machine for anyone to say “if you do “A” to your machine, it will definitely give you result “b”. Try a few things...leaving it 1 3/4” and drilling the stock box is pretty easy. Try that, if it makes you happy, run it. If not, move on to the next step.
