Final water routing question on 02 F12X... I hope
Results 1 to 2 of 2
    Resident Guru zoomjay's Avatar
    Aug 2005
    Denial, VA
    I think that this post got lost in the previous thread. I thought I had the water routing right although am missing something. Question is here..
    Well, I thought I had it all worked out... I put the rest of the exhaust system on it and find I have an extra nipple that needs a hose (pun intended). The diagram I have (like the one posted) is for a 2004 and I wonder if my 2002 is different. Anyway, this is where I think I am going wrong:
    The hose that goes to the outlet water nozzle (aka the "pisser" back of ski) has a T in it. One leg of the T goes to the small nipple in the top of the manifold (according to the diagram). Would appear that the other end of the T goes to the nipple coming out of the top of the exhaust body (pointing towards the front/bow).
    That only leaves me with the small nipple down low in the hull on the same fitting (exhaust manifold) where the big hose from the intercooler comes in. According to the diagram, there should be a small hose split off of the main water inlet (before the water goes to the intercooler and oil cooler) that runs to this nipple although my boat has no such hose nipple (or I am missing is). Thus, what hose do I run to this last small nipple that is... well, lonely?
    Or, do I have my T connections messed up?
    Thanks.
    JL
    "Fame is fleeting although Obscurity last forever"
    Napoleon
    Aug 2005
    Denial, VA
    Re: Final water routing question on 02 F12X... I hope
    Okay, mystery solved.... I ended up with the wrong joint. The one I need for the bottom of the manifold should not have a nipple on it. Thus, no lonely nipple...
    Napoleon
