750 sxi turning but not running
Results 1 to 10 of 10
    PWCToday Regular ryanstandup's Avatar
    SoCal
    Took my sxi into the waves a last month. Accidentally took on some water. Ski wouldnt start on the beach. I took it home and slowly got it started after taking spark plugs out and spraying starter fluid in it and trying to dry it out. Finally got it it to start with new plugs and ran fresh water through it for a while.
    Now I try to start it and it turns and cranks but wont get a full turn over and wont run for more than 5 sec. I am using the choke all the way on when I first try to start it and turn it off after it wont get started. Any help on why it wont start now after I was able to get it to start last month?
    Ive tried the simple things like battery fully charged and new spark plugs but still not luck. Could it be a bad mixture when Im choking it?
    Thanks for the help
    Frequent Poster Kawy750's Avatar
    Jan 2008
    Connecticut
    Re: 750 sxi turning but not running
    Start simple. Confirm that you have good compression, spark and fuel. Did the motor get hydro locked when you took on water? I’ve heard you can mess up carb diaphragms when that happens. Also never turn the motor over with the plug wires disconnected. This can potentially damage your coil. They should always be grounded to a plug or spark tester. I had an sxi where the stator went bad. Just out of the blue wouldn’t run anymore. Not sure how to test that. You are in the right place. I’ve learned a lot and continue to learn from the help and wisdom on this site.
    08 Superjet
    Limited B pipe, Girdled ADA 35cc, Toby footholds, Riva scoop and stock D cut ride plate.
    87 300sx
    My EX's
    81 440/650
    89 550
    89 650
    96 SXI
    Jan 2008
    Connecticut
    Also. Use starter fluid with moderation if at all. It’s not the best thing for a 2stroke engine. Your better off with a small can of mixed fuel to dribble in the carb if necessary.
    08 Superjet
    87 300sx
    My EX's
    81 440/650
    89 550
    89 650
    96 SXI
    Could be water in your carbs, fuel tank, electrical box, stator cover, etc. You need to take things apart, clean, and inspect. Also check your reeds. It is not uncommon to bend/break a reed when the engine gets water in it.
    email watcon@watcon.com
    Please visit our web sites
    SoCal
    Put in a carb rebuild kit.... not sure this is what my carbs are supposed to look likeF70D99D2-9CA3-494D-9811-ABBE04C7904A.jpeg
    SoCal
    Still need to adjust the carb settings. Will my manual say the correct settings?
    Thinks everythng sux =) Top Dog vomitspot's Avatar
    Mar 2005
    lost
    take yhode sbt kits to the trash
    only mikini kits or you will be creating snother problem
    carbs deff need to be cleaned
    nina hagen daz
    Feb 2002
    Vancouver, BC Canada
    Do not use those carb kits, use only genuine Mikuni kits or you will have problems.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Mar 2005
    lost
    seen it 1000 times someone wanting to save $1 on cheaper kits only to spend more on getting someone to fix same issue w oem kits
    nina hagen daz
    Riverside, CA
    6
    You need to inspect your gas cap (has it ever been replaced?),
    is the rubber gas cap gasket missing???
    It is more likely that the water inside your carbs came from the
    fuel tank, and not when you sunk the ski.
    You should also drain the tank and mop it clean before you ride
    it again.
    Bill M.
    old post
