2006 Yamaha FX Cruiser HO (second) rebuild - Page 6
Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
  1. #51
    Re: 2006 Yamaha FX Cruiser HO (second) rebuild
    There was just somebody on Greenhulk that had a salty wiring harness. Might be able to sell it to them.
  2. #52
    Aug 2015
    royersford pa
    Hi all - just wanted to close out this thread. Finally got a nice warm weather day to take the ski out on the water. hitched up the trailer and got down the river, started up after 2 secs on the ramp. Then lowered into the water and it was rough starting, wouldn't turn over completely. Odd, I thought. Out of the water and after some coaxing, it was running smoothly. Not sure why. Ran up and down the river at various RPMs, no wake and on plane. kept it under 8k rpm for the entire hour or so on the river. ran smoothly with no sounds or signs of problems. Will be changing the oil and filter over the weekend to see what that shows, will even split the old filter open to see what it caught from the new engine oil. All in all, pretty happy that the long winter repair was successful and I learned a boat-load (pun intended) about motor rebuilds. Thank you very much to all those who followed this thread and provided comment and guidance. I hope my experience is helpful if you own a Yamaha!
  3. #53
    great work!
  4. #54
    Yay!! I just finished my project '06 FXHO and we took it out Monday. Did about the same as you, less than 8000 rpms with varied throttle for about an hour and a half. Probably take it out again soon and crank it open a few times to really seat in the rings, then change oil.
  5. #55
    PWCToday Newbie 955i's Avatar
    Oct 2017
    Portland OR
    I just came across your tread accidentally and I noticed 2 things:
    #1 - engine is painted black, so it's probably an SBT engine and it's not original engine (someone replaced it with rebuilt one)
    #2 - I think you got your timing set incorrectly, by looking at your engine from the side looks like it's off by 2 teeth.... how is it running? are you getting 60-65mph at wot?
    Best Syncing Tool for your important pwc manuals... fully encrypted and available on all your computers... I store all my jetski manuals and other important files here.
    http://www.sync.com/get-started?_sync_refer=34243c8c0
  6. #56
    Dec 2016
    FL
    Great thread, studying all this for my current rebuild, same year and model. Did you plastigauge your bearings/journals on the crank? Tried to pm you but don't 'pm credits' apparently. Anyway great thread with lots of details, thanks!
