2006 Yamaha FX Cruiser HO (second) rebuild - Page 2
Results 11 to 20 of 56
    Aug 2015
    royersford pa
    Re: 2006 Yamaha FX Cruiser HO (second) rebuild
    Ok, now on to the second repair....
    You can see the corrosion that had formed in the exhaust port. This was the first sign of trouble...
    This is what I had to start with... workbench, tools, bags and boxes of parts (well mostly all the parts as I was to find out later...)
    You can see that there's no mechanical damage, everything is cosmetic from the corrosive affect of the saltwater on metal:
    Aug 2015
    royersford pa
    Removed the valves, then cleaned them and the head.
    Valves came up pretty clean, and within spec. I did not lap the valves
    Aug 2015
    royersford pa
    crankcase sealed, head done, cams, timing chain, and valve clearance all checked.
    Exhaust pipes installed and all cables routed correctly. ready to drop in
    I also checked the compression and it's showing a little low compared to spec, but I believe that is normal until everything breaks in.
    Aug 2015
    royersford pa
    A few videos:
    The cylinders cleaned up mostly well except for some staining from the salt water. I ensured they were smooth and honed to achieve the desired cross-hatching
    Lessons learned:
    1. Well of course I now know that towing a Yamaha Waverunner at any speed above VERY SLOW is a really bad idea.
    2. Yamaha should have included a "tow valve" which could cut the supply of cooling water through the cooling water intake pipe.
    3. Learning a new skill is an awesome experience.
    4. Make sure all parts are accounted for before you start the project. Having to go back and forth to the shop 5 times delayed the project.
    5. Procure all your consumables ahead of time (molyb grease, thread lock, etc.)
    6. Make sure you have all required tools before you start the job. Buy or borrow what you don't have.
    7. Always helps to have a brother who has done this before, and is nice enough to sacrifice his time to answer questions whenever you get stuck or need confirmation.
    8. READ THE SERVICE MANUAL and follow its advice.
    9. Be extremely careful and diligent with the timing. Mark a spot with white market where the crankshaft enters the case, ensuring cylinder #1 is Top Dead Center (TDC). You must ensure the crankshaft does not move when you are installing and torquing the cam covers. The chain guides are a little tricky to install, while ensuring the chain stays tight around the gears, and the crankshaft does not turn. Keep all the slack in the chain in the section where the timing chain tensioner will go, ensuring that there is no slack in the timing chain between the two cam gears, and between the cam gears and the crankshaft.
    10.The rings are a pain in the *** to install and then get the piston into the cylinder. The first time I did it, I was playing with the piston and accidentally pushed it too far down the cylinder, causing the oil ring to pop out. Spent about an hour trying to recompress it, to no avail. Had to pull the oil ring, slide the piston up, and replace that ring. Wasn't going to take any chances there. That delayed me several days and set me back another $30 for the ring set.
    11. use a very small amount of gasket maker on the mating surfaces of the crankcase. I used too much the first time and had to re-do. not fun and a waste of time.
    12. Have fun!!!
    Aug 2015
    royersford pa
    Crank was smooth after pistons were installed.
    Aug 2015
    royersford pa
    Crankshaft with piston movement
    Aug 2015
    royersford pa
    Ensure the timing chain is tight after installation
    Aug 2015
    royersford pa
    A full walk around of the engine after re-assembly, just before dropping it back into the ski
    Lastly, here are two links that discuss how to install the cooling water (tow) intake valve.
    https://jetboaters.net/threads/dont-...g-towed.10842/
    https://jetboaters.net/threads/how-t...ng-system.411/
    Aug 2015
    royersford pa
    just posted a bunch of pictures and some videos. Hope this is helpful to your project. Feel free to PM if you have specific questions.
    How did you enjoy all that bearing plus and minus.....blue, red,green, etc...crap!
