650 gasket kit
Results 1 to 2 of 2
Thread: 650 gasket kit
    Apr 2008
    DFW
    650 gasket kit
    Hi SBT, maybe I just got a bad set but I wanted to let you know that the gasket kit that I bought along with your 650 reman engine has a badly made exhaust gasket that doesn't seal the water jacket.
    Hopefully this problem can be fixed so future customers don't have the same issue I did (I made my own gasket)
    Re: 650 gasket kit
    We will double check stock on hand to see if there are any more issues. Can you contact us (Cliff at warranty@sbt.com) so we can look up your order and try to find approx when this occurred? We can then inspect all of the gaskets from that shipment to make sure there aren't any other issues. Thanks for the heads up!
