new 62t wsm stator timing
    PWCToday.com Is My Home Away From Home SBrider's Avatar
    Nov 2009
    santa barbara/redding
    replacing a oem stator with a wsm, both are 62t , looks like the stator plate and timing mark are way off, any ideas. running this in a jet maniac motor with msd so i don't want the timing advanced anymore than it already is
    Re: new 62t wsm stator timing
    Send that WSM one back...…
    Stick with OE, either good used, or send yours off to John at Jet Ski Solutions...
    Please visit our web site
    Nov 2009
    are they known to fail? its a customers ski, he already had the stator.
    Nov 2009
    ok so the oem one is a 61x, so does that mean the 62t has more advance if the timing mark is off,
    Quote Originally Posted by SBrider View Post
    Yes, aftermarket electrics are junk...
    No idea. You need to compare a 62t to 62t. If that is what you have in your pic, I think you have answered your own question about quality.....
    Yes, 62t runs more advance. Flywheel is also matched. If you have a 62t stator, you need a 62t flywheel. The WSM electrical are the only aftermarket I've had good luck with and will use. Have had only good experiences so far. The others........not so much lol!
    Nov 2009
    makes sense , yes i have a 62t flywheel for it.
