2005 RXP Timing Issues?
Results 1 to 10 of 15
    Nov 2018
    California
    After rebuilding a 4-Tech motor, I timed the engine using the locking tools and made sure to align the 1503 marks with the head surface. After attempting to start the engine (with no luck), i got a very loud backfire through the exhaust. Can anyone help with this?
    Nov 2009
    Burlington ON
    Re: 2005 RXP Timing Issues?
    Did you line up the crankshaft and counter balance? When you ordered parts did you order the crankshaft that covers your year of engine. 02-05 and 06 and up?
    Are you using front piston as # 1 ??
    Nov 2018
    California
    Quote Originally Posted by JO2246 View Post
    Hi,
    Yes. I aligned the two marks on the crank and the counter balance. I used the original crank and counter balance.
    Nov 2018
    California
    I timed the motor using piston #3 (front).
    Nov 2018
    California
    I checked my compression on the cylinders and came up with 140, 120, 140. Would the 20psi low on #2 cause the engine not to fire and have the big backfire?
    Quote Originally Posted by BVK View Post
    Is an exhaust valve open?
    email watcon@watcon.com
    Please visit our web sites
    Nov 2018
    California
    I am not sure? How can I check?
    Nov 2009
    Burlington ON
    I would make sure you have the crankshaft locked in properly by pulling the plug in the case and making sure its locked using the locking tool. Confirm the cam sprockets are then lined up. I would then pull to valve cover and lock camshaft to verify its oriented properly. You sure the flywheel is lined up and secured with new flywheel bolts? You sure you have spark on all 3 spark plugs. The compression numbers are not ideal because of the difference but it should run. Follow the manual step by step to lock crankshaft and camshaft. Unless you have valve damage something doesn’t seem lined up.
    Nov 2018
    California
    I have checked all of those things multiple times. I guessing I have a valve problem on #2. I am assuming I will need to pull the head not in less there is another way to check the valves in place?
