2005 RXP Timing Issues? - Page 2
Results 11 to 15 of 15
    Re: 2005 RXP Timing Issues?
    Quote Originally Posted by BVK View Post
    I have checked all of those things multiple times. I guessing I have a valve problem on #2. I am assuming I will need to pull the head not in less there is another way to check the valves in place?
    Do leak down on the #2 cyl.
    email watcon@watcon.com
    Please visit our web site
    Nov 2018
    California
    I will check that. Thanks.
    Nov 2018
    California
    Hello, I did a leak down on #2 and felt air coming out of the exhaust. However, I hear air coming from the oil fill cap on all (3) cylinders (leak down). The other cylinders had the higher compression (140psi). Would it be normal to hear some air entering into the crank case?
    Sounds like you have an exhaust valve issue for sure on the #2 cyl. Either out of adjustment, bad seat, etc. I am guessing this is where your exhaust backfire is coming from...
    May 2012
    Navarre Florida
    What engine size is it. 155 or 215
    All of the 05 engine also have the bad exhaust valves that like to brake off.
    if you have a 155 engine 140 is really low compression it should be 180-200 PSI
    If you have a 215 compression should be 130-150 or higher
    How many hours are on the engine? how long has it sat up ?
    Rob
    Owner Operator of:
    RLS Motorwork's 850-226-2748
    Currently Riding
    2006 Sea Doo RXP 215 minor mods 73.2 MPH GPS
    2004 Sea Doo GTX Limited 185 SC 63 MPH GPS
    2006 Sea Doo GTI SE 130. 56 MPH GPS
    1997 Sea Doo Sportster 717 37 MPH GPS
    Working on
    What ever customers drop off.
