Ok kawi guys question on 900 stx cv carb swap - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
    Resident Guru bossten1's Avatar
    Jul 2010
    Gardnerville nevada
    Re: Ok kawi guys question on 900 stx cv carb swap
    make sure you drill and tap for a second pulse line like the older zxi engines had . the stx may have only had one pulse line that was good enough for cv carbs but not cdk2 . should be one on each side of motor . center carb wont need one. also a lean/ low needle setting will die when you stab the throttle. try to set low to 1-1/4 and high to 1
    2006 SXR
    87 550
