99 GSX RFI Flywheel
Results 1 to 8 of 8
    May 2017
    New Holland
    99 GSX RFI Flywheel
    Can you split a 99 RFI flywheel??
    If so what is the best way to do it?5C88DD2A-2C64-4B12-A26B-CDA9FB501478.jpeg
    Re: 99 GSX RFI Flywheel
    Nope & why do you want to do that ??
    May 2017
    New Holland
    I knew you were going to ask why...
    I did a bunch of research (and your reply was part of it in a different thread) I am using a 787 RFI crank and case to put together a 787 carb back up engine for my 97 GSX. I know that I have to use the RFI flywheel because the cranks are different. I just figured I could shed a touch of weight if I could remove the front part of the flywheel.
    After I posted this thread I was looking deeper into it and I was guessing even if I could split it, there would not be enough structure in the center of the flywheel for strength.
    That wont work as you need a "carbed" flywheel to run a carbed motor.
    I used a carbed crank in RFI cases.
    May 2017
    New Holland
    You have always been right so I am definitely not arguing. This is what I was basing my build off of:
    Look at Justforfuns post
    http://www.pwctoday.com/showthread.php?t=265845&page=2
    I stand corrected.
    May 2017
    New Holland
    I stand corrected.
    Well here is the thing. I have a complete electrical system back up for my GSX so I figured I can get the engine together ad try to bench run it. If it works, great if it doesn't I have a 787 carb crank I can get rebuilt., SO, no harm no foul to try, But what I don't want to say yet is that you stand corrected. I am in no rush. Guessing I will have it done by early spring. So we will know then if it works.
    You are the Super Stud of PWC and like always, thanks for all your help!!!!!!
    aw shucks.
