1996 GTX no spark
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    Mar 2018
    Missouri
    1996 GTX no spark
    Picked up a winter project and not getting any spark. Was readibg through a bunch of the other threads and got alot of testing to do. But thinking need to repleace the CDI given looks like was in the box loose, bottom plastic is ate through to circuit board and tops looks like this. 19892.jpeg
    Re: 1996 GTX no spark
    Start with the basics. Make sure voltage does not drop below 11v while cranking. Ohms check the 3 yellow wires for the stator. Less than 1 ohm between any 2 and no continuity from any yellow to ground.
    This, and take the plug boots off, and cut the wires back a 1/4" or so to get into good plug wire.
    email watcon@watcon.com
    Please visit our web site
    Start with new MPEM....
    Mar 2018
    Missouri
    Thanks ill check all that but figured as burnt as that was it needed replaced regardless. None of the gauges work at all either so got alot of testing to do.
    Frequent Poster daget24's Avatar
    Feb 2013
    santa barbara
    Quote Originally Posted by grumpy old guy View Post
    start with new mpem....
    x2.
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Mar 2018
    Missouri
    What all years interchange, I know where a complete electrical box is but its from a 96 XP or GSX. Looks same minus the CDI amplifier. Not sure if it was just robbed since looks like pigtail is there. Screenshot_2018-12-16-14-34-02~2.png
    96 XP and GSX would probably work , you need to double check the MPEM part numbers on some place like Worldofpowersports.com also you can usually type in the OEM Seadoo part number in Google and it will usually direct you to a site that will tell you what that MPEM fits.
    Mar 2018
    Missouri
    Got a new mpem and will get programmed after holidays. Noticed on the wiring going up sreering column the sleeves on all of them even throttle and steering cables have been warm. So assume one of the wires had a short. The dess wiring has been worked on the connector on handllebar side and pins shoved in other side. The two two wore harness seem the worst so want to check them out before putting mpem in. What does the purple and tan or orange with black stripe control. The black ans yellow with red stripe looks like it was prettyy warm as well believe thats the start stop switch. One of the info control center buttons is pushed clear in and doesnt work is that what other wiring controls?
    Mar 2018
    Missouri
    Tore into it a little and the wiring that burnt is for the beeper. The beeper still does work but would the mpem burning like it did cause that wiring to burn? Plan to replace it to avoid having a short causing more issues. It doesnt smell burnt though and since the choke and throttle cable has sone spots that got hot wonder if previous owner had a light or something in machibe when working on it and thats what got everything hot. 1223181119a.jpg
