1996 GTX no spark - Page 2
Results 11 to 20 of 28
    Re: 1996 GTX no spark
    Melted from electrical shorting.
    Mar 2018
    Missouri
    Thanks I wasnt sure. Maybe thats wby bepper isnt always consistent when hooking up dess
    Quote Originally Posted by cfast View Post
    Thats normal...
    Sad but true.
    May 2009
    the 'ville, kentucky
    my beeper never has worked
    Mar 2018
    Missouri
    Havent gotten new mpem programmed yet since may buy another and want keys to match. The wife has been complaining of gas smell so decided to check out the fuel lines. I cleaned the inside of hull thinking was just leftover from previous owner working on and then found the gas tank wasnt venting. Previous owner had changed out fuel lines but tried to bypass the fuel selector. He had the vent just looped back to return, pulling fuel from on and returning to reserve all on the sending unit.
    I got some gates fuel hose on order and just gonna replace what they had done already. Pretty sure right but feed for carbs is the back line that splits to both carbs and the return just on front carb. Also should feed line run under carbs and around are over top?
    Also the previous owner tied both vents to the oil tank, should this be vented if so where is proper place?
    Also noticed alot of white powder sitting in top of carbs and these three Allen head bolts are completly full. Anyone seen anything like this and is it something to worry about?
    Mar 2018
    Missouri
    Just wanted to double check now that shorted wires replaced and I can get spark with the mpem that has melted so thats good. Hopefully getting fuel lines in right place will fix rest of problem.
    Both fuel and oil tank NEED to be vented.
    Fuel tank sending unit is marked with "Vent, RET, ON, and RES"
    Your white powder looks like corrosion. Not uncommon on a ski that is stored wet.
    email watcon@watcon.com
    Please visit our web sites
    Mar 2018
    Missouri
    The oil tank just vents right on top of tank though right? He had it tied to the tee for fuel line venting.
    Figured would clean the rave valves as well since who onows when was done before if ever. It has the original red bellows at this age should they be replaced or just clean up and new orings.
    Also plan to drain oil tank and replace filter, and small oil lines since still factory. Plan to run mystic full synthetic.
    No the fuel inlet is on the front carb , return is off of the rear carb on the hose that splits and goes to both carbs
    Mar 2018
    Missouri
    Thanks will get that fixed once new hose and clamps come in.
