1994 Seadoo XP Not Running Right
Results 1 to 6 of 6
    Dec 2018
    Outside US
    Hi guys!
    New here and to the world of pwc.
    I own a 94 Seadoo XP.
    I am having problems with my ski, upto half throttle is fine then from there to full throttle does not rev anymore. Stays below 5000rpm. And bogs/surges between 4 and 5k with throttle wide open. I think full throttle is meant to be 7000rpm??
    The previous owner said he had carbs rebuilt about 6 hours ago and was using premix of 32:1.
    First day I got the ski it was running well, then I was using 40:1 premix and since then has been running poorly.
    Could this be due to needing to still be 32:1 or clogged carbs?
    I have just purchased some fuel set, hopefully this will clean the fuel system.
    Should I strip/clean carbs and or rebuild?
    Any info would be much appreciated!
    TIA.
    Dec 2018
    Outside US
    Re: 1994 Seadoo XP Not Running Right
    Forgot to mention that I purchased a month ago and have taken it out 4 times since. I have also drained the fuel, replaced with new premix fuel and replaced the fouled spark plugs.
    Riverside, CA
    6
    Was there any water inside the fuel filter bowl. Did you replace the o-ring?
    Does it smell like gasoline when you lift the seat off?
    What is the pop-off, what size are the seats, and which spring is inside
    the carb?
    Bill M.
    Perhaps the previous owner can help?
    Dec 2018
    Outside US
    Hi Bill
    I have not looked at anything/replaced anything as I am not really sure where to start other thern drain fuel and change plugs.
    It did kind of smell like fuel when I lifted the seat off...
    Cheers
    Those fuel tanks are known for cracking at the necks...filler & fuel pickup neck.
    Fuel leak will cause running issues.
    Dec 2018
    Outside US
    When draining the fuel I didn't notice any cracks on the necks...
    Will have a closer look tonight.
