I Am At the end of the rope !! Anyone ????
Results 1 to 9 of 9
    Resident Guru Mackzilla's Avatar
    Feb 2007
    Douglas , Ga.
    Got a Polaris msx 140 2003 year model two stroke 1200 DI . I have replaced the TPS which by the way was not easy to find nor was it cheap but still have the same issue. The ski will crank and run but seems to be in limp mode, you can hold at WOT and it just revs in and out. I have no way to hook a computer to this so you can see this has been a guessing game. Has anyone else seen this problem ???
    MACKZILLA JETUNLIMITED
    Re: I Am At the end of the rope !! Anyone ????
    Have you considered setting it on fire ?
    Oct 2013
    funky town
    I'm in for 5 gallons of gas.
    I'm only here to make you mad
    Aug 2010
    delavan, wi
    Seeing what happened to Polaris injected PWCs has ensured I will never buy a fuel injected ski, at least two stroke. You should just rip that fuel injection crap off and throw carbs on it, it's been done before.
    90 Superjet - Coffman pipe, other mods
    98 Polaris Pro 785 - stock graphics, just ported and polished
    98 Polaris Pro 785 - black top, cylinders milled .020, ported, polished, watcon cooling
    95 Kawasaki 750 sxi - R&D pipe, ported, polished, bored 1.5mm over
    01 Polaris 600 sc xp sled - Stock
    Have you already inspected the fuel pressure regulator?
    Resident Guru TxPro1200's Avatar
    Feb 2004
    tejas
    fuel pressure regulator would be my guess
    2000 pro 1200 69.1 gps
    2000 virage tx 67.8 gps
    2000 virage tx 62.3 gps
    Sep 2002
    Upstate NY
    Have you confirmed all the basics? Compression good? Spark on all 3 cylinders? Correct spark plugs installed? Fuel pressure in spec? Injector volts while running? Is the check engine light on?
    FICHT EMM Repairs (Polaris, Kawasaki, Tigershark)
    http://lakesidetech.biz/
    http://fb.me/lakesidetech1
    Michigan
    Have you checked compression in all three cylinders?
    Oct 2013
    funky town
    Check the basics, as Nate said. Comp. is as basic as it gets, then fuel and air. Suck, bang, blow. That's how they work.
    Why not get a real diagnostic instead of throwing parts/money at it?
