Battery Draining - Page 7
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 78
  1. #61
    Oct 2013
    funky town
    Re: Battery Draining
    Have you checked the voltage on the battery, not in the ski, given the same time frame?
    Dude, there comes a time when you need to tap out, for your own good.
    You've been given all the info you need, and you still can't figure it out. There's your sign.
    I'm only here to make you mad
  2. #62
    Aug 2018
    Texas
    Why do you care? Was just keeping the people who have assisted in the loop -- I appreciate the time they have spent. #NoResponseNeeded
  3. #63
    Aug 2018
    Texas
    Have you checked the voltage on the battery, not in the ski, given the same time frame? .
    Yes, it holds charge. Held at 11.89 consistently for ~4 days. Was at 11.89 since it drained to that level prior to disconnecting (and I didn't recharge).
  4. #64
    Sin City USA
    If you disconnect the positive from the battery, and use your multimeter set on ADC (DC amps), connect one lead to battery + and the other to the disconnected positive cable you should be able to read any significant amp draw on the battery. If it is zero then I would assume that there is a problem with the condition of the battery itself. If it shows amp draw (current) then you will need to find the short
  5. #65
    Aug 2018
    Texas
    I've been doing this several times; yet today I borrowed a friend's Klein MM700 multimeter and was able to get a more detailed reading. Photo below shows a 0.07 drain.drain.jpeg
  6. #66
    PWCToday Newbie jusdpomme's Avatar
    Aug 2018
    Canada
    There you have it. Now follow your first reply:
    [...]just unhook one component at a time. When [you get 0.00 amp], you've found the culprit.
    '95 SPX
  7. #67
    Aug 2018
    Texas
    Quote Originally Posted by jusdpomme View Post
    I may have found the culprit (see photo). The 3 pin connection with brown and black wires. I've looked up in the manual; yet unsure what exactly it is. Does this lead to a "coil"? connector.jpeg
  8. #68
    Sin City USA
    That leads to the stator, on the front of the motor. Open up the front cover and inspect, it may be obvious (oil or water corrosion) what is causing the short. I have seen several times where people have filled the front of the case with oil, confusing the inspection hole with an oil fill. There could be water intrusion damage as well, or even damage caused by a failed front seal or even a bendix spewing metal shavings.
  9. #69
    Jan 2007
    Earth (but just visiting)
    +1 with Jonny. Also if your rectifier is burned out your battery will back charge your charging coils (in the front of the engine) and run down your battery.
  10. #70
    Aug 2018
    Texas
    Quote Originally Posted by ericstratton View Post
    This sounds expensive...
