Start button turns over engine even with out key? - Page 4
Results 31 to 35 of 35
  1. #31
    Sep 2015
    Northern Michigan
    Re: Start button turns over engine even with out key?
    You can replace it. Or get another key any should work.
    But I think you can remove it. Do a search ( 97 seadoo xp msd dess delete)
  2. #32
    You can take the 2 wires that are attached to the switch & join them together & see if it stays running.....
  3. #33
    Sep 2015
    Northern Michigan
    You can get a replacement for the 42.00. I don't think it's operating as a dess, it's just a kill switch right now. Try using any let on it. If you replace it you still have a kill lanyard.
  4. #34
    PWCToday Regular extremeXconcepts's Avatar
    Jul 2016
    washington, ct
    Thank you for all the ideas everyone I think what I'll do is try to attach the 2 wires together to confirm that it does stay running and that it is the dess post if that works then ill replace it
  5. #35
    Dec 2011
    Niceville, FL
    Many racers with that system went back to the pre-DESS spring loaded button and lanyard.
