Start button turns over engine even with out key? - Page 3
Results 21 to 30 of 35
    Sep 2015
    Northern Michigan
    Re: Start button turns over engine even with out key?
    I am curious about your electrical system can you post some pics. It sounds like your running a 787 MSD enhancer.
    PWCToday Regular extremeXconcepts's Avatar
    Jul 2016
    washington, ct
    I wonder if the obly function left on my post is magnetic on off switch (kill switch) someone told me the key and post utilized some sort of magnetic thing. So thats why like a crazy mad scientist i grabbed a magnet for hahas and it worked. Haha
    Jul 2016
    washington, ct
    Yea i can take a few pics shortly
    Jul 2016
    washington, ct
    Sep 2015
    Northern Michigan
    Have you tried to start it several times and it works each time.
    Jul 2016
    washington, ct
    Yes works every single time. Its just hard to hold the magnet exact to keep it active. But yes. I even got it 1 time with thr key and the magnet to try and hold it better. Kwy and post look and feel brand new ive used the ski maybe 20x in 3 seasons.
    The stock MPEM probably failed (normal) & somebody wired in a MSD enhanser the DESS post & key can be used as a switch to turn the MSD on any key or magnet will make the key work.
    The MSD has probably failed.
    Jul 2016
    washington, ct
    So if my key alone is not activating this properly. Is it the post or the key? Or what should my next action be? If im able to hold the magnet perfectly it will run and stay running soon as i move it even the slightest it shuts off
  9. #29
    Jul 2016
    washington, ct
    I am unable to keep it running via magnet. But it does activate the electronics and fires between 1 second and 10 seconds. I dont know if its me moving the magnet. Not a strong enough magnet. Or a super faulty dess post
  10. #30
    Try another key
