Start button turns over engine even with out key? - Page 2
Results 11 to 20 of 35
    PWCToday Regular extremeXconcepts's Avatar
    Jul 2016
    washington, ct
    Re: Start button turns over engine even with out key?
    Was 14.1 at starter solenoid
    Jul 2016
    washington, ct
    Your jet ski let you crank the motor over without a key on the post because of a low battery?
    Sep 2015
    Northern Michigan
    Quote Originally Posted by extremeXconcepts View Post
    yes
    Sep 2015
    Northern Michigan
    Well if you have checked everything and it sounds like you have the MPEM may be gone.Any other ski you can swap it into to check it.
    Jul 2016
    washington, ct
    im not even sure this machine has a factory mpem? only thing up front is a rectifier and a bigger MSD box im assuming MSD Enhancer? since it has another smaller msd box also mounted near the box with the starter solenoid in it. for Pulse water injection into the pipe
    Sep 2008
    The flakka capitol of Florida
    Having an oem mpem or not is a huge factor in diagnosing this.
    Sep 2015
    Northern Michigan
    If you or someone else Took the time to put in a MSD ignition EGT sensor and water injection why/how is the dess post still there. If this is the system you have and no mpem , look at the stop/start button.
    Jul 2016
    washington, ct
    I just used a magnet on the dess post and was able to get it to turn on and run. Does this mean my key is bad or the post?
    Sep 2015
    Northern Michigan
    Can you take a picture of what you have for a rear box and the internals.
    Sep 2015
    Northern Michigan
    I am not sure how a dess post works , other than they are unique to the ski and mpem, so why putting a magnet on there would work I don't know I don't think on a functioning dess post that's possible.
