Kawasaki 1100 stx d fuel pumpi mystery - Page 2
Results 11 to 14 of 14
    Oct 2018
    fly over country
    Re: Kawasaki 1100 stx d fuel pumpi mystery
    So, rooted around in shed and found a bag of Bosch 5 pin relays. Found a 4 pin but its Chinese and I think the Bosch are better.
    Plan to wire the new pump through the relay with the ground being made in the emm when the relay is powered. Hopefully this will trick the emm into not sensing the true load of the aftermarket pump. Would like to power the relay from the stock harness wire that powers the pump so the shutoff lanyard works. Well that's the plan anyway. Dunno if it will work or not.
    Jul 2010
    Ireland
    Hey
    Did you get your fuel pump issue sorted I seem to have a similar issue after fitting an after market Fuel PUMP
    Oct 2018
    fly over country
    I did not finish the job. The weather turned to crap...snow and cold and all that and the job got put on the back burner till spring. I do believe using the relay will work.
    Jan 2012
    Georgia
    I have done this on a couple of DI polaris boats. The Polaris EMM is VERY picky with regard to pump amperage.
    I use this type of bosch relay:
    https://www.amazon.com/PACK-AMP-Wate...gateway&sr=8-6
    I get an OEM one, not the Chinese one. The link is just to show you the setup. The chinese connector seems fine.
    XI Sport
    GP800R
    X2
    FX140
