Aftermarket quick steer arm
    PWCToday Newbie Mwmiller30's Avatar
    Oct 2018
    Rebuilding a 1989 Js550 and am wondering if I should replace the steer arm with an aftermarket one? Iím replacing the plate/bar/etc.
    Any benefits or just a waste of money?
    Thanks!
    Frequent Poster Meeker78's Avatar
    Apr 2016
    Oregon
    Re: Aftermarket quick steer arm
    Quick steer is an essential mod! It makes turning your ski much better. You can look for complete steering plates that hold the handlebars on, or look for steering rings by ocean pro on eBay. They screw into your stock pivot nub and then extends the steering nub out farther to increase throw.
    Welcome to the forums buddy!
    Oct 2018
    Thank you for the advice!! I’ll order one.
    Apr 2016
    Oregon
    No problem. The ocean pro ring thing will be cheaper than an entire new steering plate. They both work the same except one looks cleaner than the other. But the ring can also give the “form over style” look if you do it right. Or get the ring and don’t look back. Your steering will improve either way and change the ski to a much more fun machine
