intermittent spark JS 550
    Jul 2017
    cali
    Hey techies, i am experiencing intermittent spark with a reed motor, sparks strong and runs good when it does spark. Stator ohm checks are to spec, so far I have tried a different CDI - no change, removed flywheel and stator cleaned and inspected stator for potential grounds, found none and flywheel looks new, so reinstalled them with new molex connectors and sparked at first then stopped, then tried replacing whole ebox with a spare and got spark at first then nothing. so far i have replaced everything but the stator and flywheel, stators are expensive and i don't have a spare one so at this point i guess i could try a different flywheel to see if i get a consistent spark, oh also removed the stop relay from the circuit and that wasn't it, so i am at a loss now and thought i would open it up to suggestions from the forum, please help.
    Re: intermittent spark JS 550
    Did you try with stop switch disconnected?
    Jul 2017
    cali
    yes, removed the stop relay, no change
    Post falls Idaho
    Ground that box with a jumper lead , possible bad ground @ stator , have reed stators if needed
    Feb 2016
    New Zealand
    I always start with the easiest stuff first, closest to the spark with Plugs and Caps. Work backwards from there. Ground leads, corroded or damaged e-box wires / connections, Flywheel is unlikely to cause intermittent spark I would think.
    Top Dog Rompn's Avatar
    Aug 2004
    La Crescenta, CA
    Take off the spark plug boots and inspect the wire. Cut back the leads until you get a clean wire. Re-attach the spark plug boots and go test.
    Patrick Goldsworthy
    Region 1 / Vintage Ski / #28
    Chris "Fish" Fischetti & Victor "The Slasher" Sheldon
    Jul 2017
    cali
    guys, read the post, I tried a spare ebox and that didn't change anything.
