New Piston Prototype Design With No Outside Wrist Pin Hole - Page 2
Results 11 to 14 of 14
    May 2017
    New Holland
    Re: New Piston Prototype Design With No Outside Wrist Pin Hole
    WOW!!! Talk about smarts and skill!!!!! That was awesome. I watched 3 of his vids so far.
    PWCToday Guru butterbean_29512's Avatar
    Sep 2013
    Bennettsville, SC
    It's a moot point because the wrist pin is solid....there shouldn't be any leakage between ports. Also a solid ring will not flex in the exhaust port. Not sure if that's bad or not. I would think if it did not flex in and out it would have a greater chance of snagging the top or bottom of the ring on the port. Just my thoughts....I'm not an engineer. It is thinking out of the box though.
    Cypress, TX
    The Wrist Pins in 2 Stroke Watercraft are hollow, like a tube. This is done to reduce the reciprocating mass for longer life and better acceleration.
    And because they are hollow, they could allow "communication" "tween Ports...
    Sep 2013
    Bennettsville, SC
    It has been so long since I really looked at a wrist pin....I assumed it was tapered to a solid core. I think...however...it would be easier to just come up with a wrist pin with a solid core. It is very innovative thinking...but I think that such a large hole would be researched thoroughly...especially from the Yamaha engineers.. and if it caused a problem they would have done something different in that area. The OEM design is solid....I think they are designed to communicate between ports during the scavenging sequence....and a solid WP would possibly overheat.
