RAVE valves - 2003 XP DI
Results 1 to 10 of 10
    Oct 2018
    NY
    As you prob can tell i am still going through these skis from top to bottom. One machine i am getting about 6k rpm and the other 4900-5000 and almost like a misfire.
    Is it possible its the RAVE, how do i test. There is some confusion whether they are driven by vacuum or the air compressor.
    Aug 2012
    whitby ont canada
    Re: RAVE valves - 2003 XP DI
    ya know, Seadoo has a pretty good manual, great bedtime reading, not trying to be rude,
    Sep 2015
    Northern Michigan
    Quote Originally Posted by turbosl2 View Post
    possible , clean them it only takes a few minutes. Raves are driven by crankcase pulse same as you fuel system. If it doesnt go away start looking at the fuel system, even if you rebuilt it.
    Its sad that Seadoo built such a huge POS that very few people truly know how to fix one.
    Sep 2015
    Northern Michigan
    Grumpy, your right to some degree. We still have a few good mechanics on the forum here. I have learned a great deal in short order, almost feel competent now that I have had mine appt a few times. POS is on point though . I won't buy anything other than a carb model.
    Oct 2018
    NY
    I actually am a mectand read the entire manual at work! Today I realized the rave valve were stuck due to carbon on machine 1 m. Cleaned and out back together. Both machines the water flow raves are operating fine., we will see tomorrow when I drop them in the water. But it is getting cold, 30deg in morning and 50 during the day
    Sep 2015
    Northern Michigan
    Post results please. Any pics of the build up.
    Resident Guru kartracer41's Avatar
    Oct 2010
    lodi calif.
    Seems like the 787rfi system was a lot better,why they would change to the DI system I will never understand.POS
    RGR Racing.com
    Yep the RFI platform was 100X better than the Orbital injection.
    Oct 2018
    NY
    Lol yup. Very complicated
