Anyone recognize this hose
Results 1 to 6 of 6
    Oct 2018
    NY
    Exits on the side with the fuel breather and coolant but this third one doesn’t connect to anything
    Frequent Poster Keno's Avatar
    Sep 2010
    Kansas
    Re: Anyone recognize this hose
    It may be the battery vent for the flooded cell batteries.
    96 xp - not stock
    RCW Brawler
    Braap!!
    Oct 2018
    NY
    Ahh now that makes perfect scence
    Sep 2010
    Kansas
    Almost all batteries are sealed now. So no real reason for it. You could remove it.
    96 xp - not stock
    RCW Brawler
    Braap!!
    Jun 2011
    That hose is definitely the lead acid battery vent line.
    If you trace it out. It will connect to the starboard(right side) side of the ski under the rub rail towards the front of the ski.
    Like Keno states. Most batteries are of the sealed type(I use a sealed one as well). But the wet type batteries are still sold at many stores and are slightly less expensive than sealed batteries. So I would keep it on case you go with the wet type battery and need to reconnect that vent line.
    What would Chuck Norris do?
    Oct 2018
    NY
    Yup you guys helped alot. I was scratching my head as to why this is laying up front near the engine on one machine and in the back on the other. I still have lead acid flooded batteries in these machines until they die so i will hook it up for now.
