Fabricating Your Own High Performance Cone Pipe
Results 1 to 10 of 13
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Upon hearing that one of my favorite Two-Stroke Heroes, Tim Tynan of TNT Performance, Master Two-Stroke Engine and Master Cone Pipe Builder will no longer fabricate those super cool exotic Cone Pipes, it's time to find talented new Craftsmen, Machinists and Welders that can carry the Torch for the next generations.
    To this endeavor, I'm sharing the following:
    Since the hardest part of Cone Pipe Fabrication is rolling the flat sheet metal into Cones(an Art in itself and very time-consuming), you can order them ready made at http://www.coneeng.com/conical_products.html
    Also from Cone Engineering : Cone & Megaphone List and Price.pdf Custom Cone Request (worksheet).pdf
    Pipe Tuned Length Design Nomograph: Exhaust_nomograph 1.pdf
    Pipe Design Software: https://buildandclick.com/html/tuned_pipe.html
    Flat Cone Template Calculator: http://craig-russell.co.uk/demos/cone_calculator/
    PWCToday Newbie rhyno857's Avatar
    Oct 2017
    Nova Scotia
    Re: Fabricating Your Own High Performance Cone Pipe
    Awesome post! I've been thinking of making a custom pipe for a 750 build I'm planning and this should help the design a lot.
    Cypress, TX
    Cypress, TX
    Another way of fabricating a Pipe is called Hydro-Forming.
    It involves making the Chamber out of two flat pieces, welding them together and pressurizing the flat Chamber to its final round shape. You could make a B Mod Chamber this way.
    Same method is used to repair dented Pipes.
    https://www.youtube.com/watch?v=bCsg5pQimWI
    https://www.youtube.com/watch?v=syHNyBagRlk
    Instead of a Pressure Washer, you can use a Manual Hydrostatic Test Pump:http://perfectoproducts.net/hydro-static-test-pumps/
    Have you ever priced the cones from cone engineering, I have they are ridiculous , you would go broke very quickly on a pipe design such as TNT pipe.
    Cypress, TX
    I included the Price List for all to see. Just posting different ways of fabricating Pipe Chambers for any enterprising Craftsmen.
    Cones are rolled manually and take a lot of skill and time to make. Either pay for pre-fab Cones or spend the Time making them. Time = Money. No free Lunch...
    Cheapest method of fabrication is the Hydro-Forming Method, once one figures out how to size the Template for the correct final size and shape.
    I dream skis DeMan686's Avatar
    Mar 2009
    Reno
    Sweet thanks for the Information.
    Oct 2020
    USA
    Thanks for sharing this post.
    Chicago / Portage, MI
    There is some really good info here! Thanks for posting!
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    Cypress, TX
    Here's another way to make Exhaust Chambers.
    For making small economical Sheet Metal Stamping batches, Rubber Pad Forming is the way to go.
    You can make your own Rubber Pad Former with just a Harbor Freight Hydraulic Press and a couple of thick Rubber Pads.
    Here are some Links to Rubber Pad Forming (aka vintage sheet metal stamping) to make your Pipe Chamber Halves:
    https://www.youtube.com/watch?v=xw5yEMsDxR8
    https://www.instructables.com/Protot...r-pad-forming/
    https://hackaday.com/2017/10/20/low-...t-metal-parts/
    https://en.m.wikipedia.org/wiki/Rubber_pad_forming
    https://psiurethanes.com/standard-urethane-sheeting/
    https://beckwoodpress.com/applicatio...-hydroforming/
